I don’t understand when I inquire with
properties=[‘uncorrected_energy_per_atom’, ‘band_gap’,‘formation_energy_per_atom’,‘total_magnetization’, ‘nsites’,
‘energy_above_hull’, ‘material_id’, ‘structure’, ‘grain_boundaries’, ‘is_metal’, ‘deprecated’]
docs = mpr.materials.summary.search(elements=[“Li”, “P”, “Cl”, “S”], fields=properties)
The bandgap, formation energy and hull energy is different with
opt_task_types = [
‘GGA Static’,
‘GGA Structure Optimization’,
#‘GGA+U Static’,
#‘GGA+U Structure Optimization’
task_doc = mpr.materials.tasks.search(task_ids=[tid], fields=[“input”, “output”, “calcs_reversed”, ‘task_id’, “run_type”])
task = task_doc[-1]
struct = output.structure
forces = output.forces
energy = output.energy
stress_kbar = output.stress
bandgap = output.bandgap
Could someone explain? What is going on? It should be the same. task_doc[1] is the optimization, and the output displays the final geometry/forces/stress. I want to understand how data was generated to train on Chgnet. I am extracting the raw vasp energies.
Hey @Asif-Iqbal-Bhatti, there are multiple tasks which are matched to a material, but not all tasks are used to construct properties for a material.
We often redo calculations for better data quality, but we keep all the older tasks for users to access (for data provenance, stewardship etc.)
For one of the materials you were querying for, mp-1040450, you can see on the task detail page that while there are two statics and a relaxation, only one of the statics is used to build materials properties. You can access the same task ID to material ID mapping from the API by querying mpr.materials.search(elements = ['Li','P','Cl','S'])
In the case of CHGNet / MPtrj:
- The input sets used are the MPRelaxSet and MPStaticSet in pymatgen
- The CHGNet training data includes task IDs - you can directly download the tasks you need from those, or download all of the tasks from AWS S3 and then filter the tasks you need
Thank you for the explanation. So, it means after relaxation of the structure, MP does a static calculation to compute the property. It means to train CHGNet/M3GNET, SevenNet, … on MPTraj data; the energy corrections are from the static calculation (GGA and GGA_U corrections), and the trajectories are from the structure optimization calculations (raw forces/energies/stress at each ionic step). That is why we have
task = task_doc[-1]"
task_doc[1] instead of task_doc[0] (which is for static and 1 for optimizations). In all cases, such as mpr.materials.(tasks/thermo/summary).search, By default, final raw energy is shown without any processing.
For now I want to download the data by querying via the API. I want to learn how to do it this way. People often check the convergence and energy criteria for many static runs also.
=== Now for the AWS S3. This is new for me. extracting data from JSONL files. Is there an automated way to download all files from a webpage? I see there are a lot of them, and clicking one by one will take so much time. Is there a way in pymatgen to extract data from jsonl files.
That’s often the case - for electronic structure calculations in VASP, properties like the density of states are not well-converged, and require a subsequent static calculation for better resolution
The tasks are not necessarily linked like that. At a minimum, you’d have to check that the output.structure of one task reasonably matches the input.structure of another.
Again, sometimes we spot check calculations and realize that something was done sub-optimally. In those cases, we might just rerun the final static
Take a look at our documentation - there are many ways to automate downloads from S3
Personally, I prefer using the manifest.parquet file to determine which objects need to be retrieved. You can then use pandas read_json with the lines=True option to parse the jsonl.gz files:
import pandas as pd
import numpy as np
task_section = pd.read_json(
"s3://materialsproject-parsed/tasks_atomate2/format=jsonl/nelements=9/symmetry_number=40/dt=2018-08-15-00-51-34-408170.jsonl.gz",
lines=True
task_section.replace({np.nan: None})
