Hi, I am trying to simulate elliptical vibrated cutting of CuZr using diamond tool.
Workpiece: CuZr
Tool: C
Picture 1 (orthogonal cutting):
Picture 2 (elliptical vibrated cutting):
I realised that there was no problem at all with orthogonal cutting but when I applied elliptical vibration to my tool, workpiece atoms started to penetrate my tool.
Potentials:
Cu-Zr: eam
C-C: rigid (no potentials)
C-Cu, C-Zr: lennard-jones
I tried using morse potentials for C-Cu, C-Zr as well but it didnt help.
From what I observed, I suspect that it is the cutting speed that causes the penetration, as vibrating speed is definitely way higher than tool speed during orthogonal cutting.
I have discussed with someone familiar with LAMMPS but his feedback was to try different potentials. So far, I find it not useful.
It would be great if someone could provide some thoughts/guidance. Thank you in advance.
Here is a comparison between elliptically and diagonally cutting the moment the tool comes in contact with the workpiece.
Elliptical:
diagonal:
I used command velocity for orthogonal/diagonally cutting, and fix move for elliptically cutting.
I guess this is what you meant and I believe this is the root cause as well.
May I ask for suggestions on what options do I have, in order to realise elliptical motion and also avoiding atoms penetration at the same time?
Thank you very much.
