trying to wrap lammps and the shared library is missing. how should I solve this issue?
I am running on a Windows machine in Microsoft bash launcher
make serial install-python
make[1]: Entering directory '/mnt/d/Setups/LAMMPS/src/STUBS'
make[1]: 'libmpi_stubs.a' is up to date.
make[1]: Leaving directory '/mnt/d/Setups/LAMMPS/src/STUBS'
Gathering installed package information (may take a little while)
make[1]: Entering directory '/mnt/d/Setups/LAMMPS/src'
make[1]: 'lmpinstalledpkgs.h' is up to date.
Gathering git version information
make[1]: Leaving directory '/mnt/d/Setups/LAMMPS/src'
Compiling LAMMPS for machine serial
make[1]: Entering directory '/mnt/d/Setups/LAMMPS/src/Obj_serial'
make[1]: Leaving directory '/mnt/d/Setups/LAMMPS/src/Obj_serial'
g++ -g -O -std=c++11 main.o -L../STUBS -L. -llammps_serial -lmpi_stubs -ldl -o ../lmp_serial
size ../lmp_serial
text data bss dec hex filename
7625703 179248 1808 7806759 771f27 ../lmp_serial
ERROR: LAMMPS shared library ../src/liblammps.so does not exist
usage: install.py [-h] -p PACKAGE -l LIB [-n] [-w WHEELDIR] -v VERSIONFILE
LAMMPS python package installer script
optional arguments:
-h, --help show this help message and exit
-p PACKAGE, --package PACKAGE
path to the LAMMPS Python package
-l LIB, --lib LIB path to the compiled LAMMPS shared library
-n, --noinstall only build a binary wheel. Don't attempt to install it
-w WHEELDIR, --wheeldir WHEELDIR
path to a directory where the created wheel will be
stored
-v VERSIONFILE, --versionfile VERSIONFILE
path to the LAMMPS version.h source file
make: *** [Makefile:468: install-python] Error 1
Which version of LAMMPS are you trying to compile?
It doesn’t look like you compiled LAMMPS for building and linking to a shared library, but that is a prerequisite for the LAMMPS python module, since it uses the ctypes module to load the LAMMPS C library interface.
Is there a specific reason why you cannot use a pre-compiled LAMMPS executables for Windows?
I’m using LAMMPS (15 Jun 2023), and the examples run successfully outside of Python.
I need the src to run a custom fix command (Link found here)
How can I compile LAMMPS for building and linking to a shared library?
I use the same fix in the same version of LAMMPS on a Linux-based machine (on ComputeCanada) and it works just fine. Also, I can call pre-compiled LAMMPS (executables for Windows) on my current Windows-PC using python.
If I can call LAMMPS on my windows-PC, I’m sure I can run the fix in it
Hi @akohlmey
upon compiling in shared mode, I tried to install python into site-packages folder. But I got a NoneType error. Any idea how to solve this issue?
make serial mode=shlib
make install-python
results in:
Cleaning old build directory
Purging existing wheels...
File "../python/install.py", line 84, in <module>
os.chdir(builddir)
TypeError: coercing to Unicode: need string or buffer, NoneType found
I have never seen this kind of failure before. Can you please edit the failing file python/install.py to add a print statement in line 84 so that it looks like this:
