You should be able to use the set command to zero the image flags, which is equivalent to wrapping.
Axel
Axel
Not clear what you mean by:
I was wondering if there is (or can be added to lammps that) write_data command writes the coordinates of the atoms in a wrapped form to the data file it produces.
The coords and image flags written out by write_data are inside the simulation
box with the image flags appropriately incremented, are they not?
Thanks Steve and Axel.
Yes, they are.
What I meant was, specifically, an option inside write_data command, by which we control the image flags to be zero (=wrapped coordinates).
It is not necessary, in that, as Axel said, the following command before writing the data file does the job.
set atom * image 0 0 0
I was not aware of this set image command. Thanks Axel.
