Dear All,
I am currently simulating polymer systems using LAMMPS (as of 17th February 2022). The simulations are conducted using Berendsen thermostat and NVE time integration to update the velocities.
I have employed the following commands:
fix 1 all temp/berendsen 400.0 400.0 100.0
fix 2 nve
During the simulations, the temperature is maintained at 400K+/-2K (with some fluctuations), and the simulations run successfully. The results obtained are fine to me. However, I encountered a problem while writing the data file at the end of the simulation using the ‘write_data’ command. The velocities recorded in my output data file are the same as the input data file. Is this correct? or should the velocities have been updated?
Thank you,
