I am trying to output the charge and bond order during molecular dynamics simulation using ReaxFF. The line in the input file related to this is:
output qbo append charge_BO
When I run GULP (6.3.2 latest version), it terminates with the following compiler error
At line 85 of file …/outqbo.F90 (unit = 24, file = ‘charge_BO.qbo’)
Fortran runtime error: Sequential READ or WRITE not allowed after EOF marker, possibly use REWIND or BACKSPACE
I think I need to modify the source code somehow, but I could not pinpoint the needed modification. Any help is appreciated.
Hi Mostafa,
Sorry for the issue. I’ve amended the code for version 6.3 & 6.3.2 to avoid this, and so if you update your source it should be fixed I hope.
Regards,
Julian
Because the charge calculation isn’t strictly an MD property it’s not handled by the “sample” option & so the charges are output whenever they are recalculated. I’ll try to connect the option to sample during MD runs for the next release.
Regards,
Julian
