The ion entry of Sn was in a wrong name:
the ion entry with composition Sn1 O2 H1 has name SnOH2[+1]
the ion entry with composition H1 Sn1 O2 has name SnOH2[-1]
As printed out, the number of O and H are opposite
mpr = MPRester()
entries = mpr.get_pourbaix_entries([ "Sn"])
for entry in entries:
print(entry.name,entry.composition )
The output is:
Sn[+2] Sn1
SnOH[+1] Sn1 O1 H1
SnOH2[+1] Sn1 O2 H1
SnO3[-2] Sn1 O3
SnOH2[-1] H1 Sn1 O2
Sn[+4] Sn1
Tagging @rkingsbury here to see if he can help.
To materials project staff, this may be a general problem because I find the same mistake for Cu-O-H ion:
Hmm this looks concerning, thanks for pointing out @yuxin-chang . This looks like a bug in Ion.reduced_formula (which I think may be the same as one that I recently identified for other reasons).
This issue (I think) is here.
@property
def reduced_formula(self) -> str:
"""Returns a reduced formula string with appended charge. The
charge is placed in brackets with the sign preceding the magnitude, e.g.,
'Ca[+2]'. Uncharged species have "(aq)" appended, e.g. "O2(aq)".
reduced_formula = super().reduced_formula
charge = self._charge / self.get_reduced_composition_and_factor()[1]
chg_str = charge_string(charge)
return reduced_formula + chg_str
Ion should be using its own reduced_formula, not the one inherited from Composition.
@yuxin-chang would you mind opening an Issue in pymatgen? This is on my radar to investigate but I won’t get to it for a week or so.
