Dear developers
Thanks for your hard work developing such an amazing package.
Recently, I’m trying to calculate thermal conductivity of SnSe (Pnma phase).
Learning hiPhive is a little hard for me. So I use a wrapper code named ‘hiPhive Wrapper by NML’ which is very useful for VASP users.(GitHub - NewMaterialsLab/hiPhive_wrapper_NML)
I test the example of Si and the result is about 150Wm/K which is in good agreement with experimental and theoretical values.
Then I apply the workflow to the SnSe (anisotropic) structure and the results are terrible (about 0.02 0.056 0.059 W/mK).
Structure Generate
- “Number of structures” is set as 20.
- The POSCAR contains 8 atoms and SPOSCAR is 2x4x4 supercell (256 atoms).
- “Rattle amplitude” is set as 0.02. (Maybe this is the key and I’m calculating the “0.2” case)
Cut off
I set the cut offs as “7.0 5.0 3.0”.
If I increase the cut offs like “9.0 7.0 5.0”, the error comes “Exception: Found cluster (0, 16) twice, check cutoff!”.
If I reduce the cut offs like “5.0 3.0”, ShengBTE cannot get converged.
Fit method
I have tried different fit methods. Here is Summary.
Thermal conductivities by different fit methods are similar.
seed : 42
fit_method : rfe
standardize : True
n_target_values : 15360
n_parameters : 1038
n_nonzero_parameters : 1038
parameters_norm : 712.098
target_values_std : 0.07267954
validation_method : shuffle-split
n_splits : 5
rmse_train : 0.007869026
rmse_validation : 0.008548121
R2_validation : 0.9864213
rmse_train_final : 0.007896464
R2_train : 0.9881957
AIC : -146650
BIC : -138720.1
train_size : 0.8
test_size : 0.2
seed : 42
fit_method : ardr
standardize : True
n_parameters : 1038
n_nonzero_parameters : 171
parameters_norm : 167.0925
n_splits : 5
rmse_train : 0.009877123
rmse_validation : 0.01007643
R2_validation : 0.9811318
rmse_train_final : 0.009927941
R2_train : 0.9813408
AIC : -141351
BIC : -140044.6
train_size : 0.8
test_size : 0.2
seed : 42
fit_method : lasso
standardize : True
n_parameters : 1038
n_nonzero_parameters : 828
parameters_norm : 594.2445
alpha_optimal : 0.0002712273
n_splits : 5
rmse_train : 0.007912225
rmse_validation : 0.008450503
R2_validation : 0.9867296
rmse_train_final : 0.007981723
R2_train : 0.9879394
AIC : -146740.1
BIC : -140414.5
max_iter : 5000
train_size : 0.8
test_size : 0.2
1.Could you please tell me if there is any obvious error or which parameter should be tested.
2.In the folder “hiphive-examples-master\examples\Si_bulk\kappa_hyper_curve\pdf”, there are a lot of tests about “num features” by different fit methods. I found that results strongly depend on the “num features”. The “num features” would increase with increasing “cut offs”. But these figures show that small “num features” tends to exhibit “good” thermal conductivity. Am I right?
Thanks a lot
Sincerely
Wei Cao
