neighbor 2.0 bin
However, there is no interaction between D projectile with the substrate. Reducing time step does not do any good. Do I miss something about LAMMPS syntax or zbl parameters are not correct for the simulation?
neighbor 2.0 bin
or perhaps the projectile is moving too fast?
you can always verify, if the specific potential makes sense, by using the
pair_write command and then plotting the potential energy curve and
comparing it to plots from literature or potentials you know well.
