Hi everyone,
I am using LAMMPS to evaluate the decay of NMR signal in magnetic field gradient. I have written a “compute” that evaluates the accumulated phase of each particle after each time step. I dump the phase after a set number of timesteps. While this works with no problems on one node, and for shorter simulations, at longer evolutions the output phase for some of the particles becomes zero.
Here is how I prepare my output:
compute NMRsig all NMRsig ${omegax} ${omegay} ${omegaz}
fix signalf all ave/atom 1 1 1 c_NMRsig[*]
dump NMRsig_out all custom 10000000 nmrsig200_1.txt id f_signalf[*]
dump_modify NMRsig_out sort id
#number of steps to run
run_style verlet
run 1000000000
And here is a set of output
ITEM: TIMESTEP
10000000
ITEM: NUMBER OF ATOMS
1000
ITEM: BOX BOUNDS pp pp pp
-1.7000000000000000e+02 1.7000000000000000e+02
ITEM: ATOMS id f_signalf[1] f_signalf[2] f_signalf[3] f_signalf[4] f_signalf[5] f_signalf[6]
550 1 -3.55613e-05 1 1.51378e-05 1 -3.99799e-06
551 1 2.68159e-06 1 -2.86324e-05 1 -7.39508e-06
552 1 3.20163e-05 1 -2.91998e-05 1 3.03028e-05
553 1 1.48324e-05 1 -3.1044e-05 1 1.81926e-05
554 1 1.89969e-05 1 -1.43878e-05 1 1.79598e-05
555 1 -2.38021e-05 1 6.45593e-05 1 -3.14228e-05
556 0 0 0 0 0 0
557 1 -2.5495e-05 1 -3.21013e-05 1 -8.20196e-06
558 1 -1.02374e-05 1 -1.53342e-05 1 4.43111e-05
559 1 -4.53915e-06 1 -3.78215e-07 1 1.11562e-05
560 1 -1.44737e-05 1 -1.52298e-05 1 -4.23223e-05
561 1 3.33534e-05 1 5.21771e-05 1 6.90638e-06
562 1 -8.80949e-06 1 -9.83268e-06 1 2.66596e-06
563 1 -2.12596e-05 1 -1.92553e-05 1 -2.27869e-05
564 1 -5.033e-06 1 2.88323e-05 1 1.61323e-05
565 1 -3.56757e-06 1 2.81538e-05 1 1.95783e-06
566 1 -3.42753e-05 1 -1.31754e-05 1 1.56249e-05
567 1 4.85273e-05 1 -7.47894e-05 1 -8.89502e-06
568 0 0 0 0 0 0
569 1 -2.22802e-05 1 1.06457e-05 1 7.42265e-06
570 1 3.90405e-05 1 -1.16549e-05 1 -3.92964e-05
571 1 -2.32027e-05 1 2.17756e-05 1 -4.24659e-06
572 1 2.69602e-05 1 -6.13531e-06 1 4.6356e-05
573 1 -3.37474e-05 1 -2.0135e-05 1 -8.65166e-06
574 1 -4.48482e-05 1 0.000130097 1 -1.80315e-05
575 1 -2.99853e-05 1 -2.1133e-05 1 1.50947e-05
576 1 1.3288e-05 1 -9.63368e-06 1 2.16961e-05
577 1 3.22323e-07 1 3.24864e-05 1 -2.25511e-05
578 1 -1.12512e-05 1 2.51472e-05 1 2.46447e-05
579 1 2.82556e-05 1 -1.92971e-05 1 1.15178e-05
580 1 3.33253e-05 1 -1.36951e-05 1 2.15541e-05
581 1 4.26993e-06 1 -4.16841e-05 1 5.44215e-05
582 1 -8.09298e-06 1 -5.64074e-05 1 -1.69614e-05
583 1 -2.15552e-05 1 1.30414e-06 1 4.55563e-05
584 1 5.98638e-06 1 -2.47841e-05 1 -3.21058e-05
585 1 5.45646e-05 1 1.00233e-05 1 3.5604e-06
586 0 0 0 0 0 0
587 1 -8.23416e-06 1 2.84374e-05 1 -1.42745e-05
588 1 2.23211e-05 1 -2.18053e-05 1 -3.46998e-06
589 1 -7.45714e-06 1 -9.49005e-06 1 1.7271e-05
590 1 -1.46878e-05 1 4.53119e-06 1 -7.63254e-07
The location of zero output is different at each time step.
Any idea what could be the cause and how to avoid this?
