Dear Sir/Madam,
I’ve been trying to run a 2D simulation on a simple hexagonal system (resembling a graphene sheet).
The potential that we are using is very simple and consists of only harmonic bonds and angles; there are no non-bonding interactions or dihedrals etc…
I’ve generated the structure on material studio v6.0 and have converted the structure into a readable format via msi2lmp and have made some slight modifications to the file to suit my needs.
I’m running a simple minimization simulation however the program is returning a number of warnings which are:
- WARNING: Inconsistent image flags (…/domain.cpp:594)
- WARNING: Bond/angle/dihedral extent > half of periodic box length (…/domain.cpp:667)
I’ve checked the system using VMD and it appears that the atoms at the boundary are not bonding with their image atoms but with the atoms in the same cell (as can be seen in this image: http://tinypic.com/view.php?pic=2j29euc&s=5#.UrgQ0vRDtl0).
I’ve defined all of the bonds in the structure file (even bonds crossing the image plane) however the problem still persist. From the diagnostic tests that I’ve carried out it appears that the bonds crossing the periodic boundaries are being bonded with atoms within the same cell. I’ve tried searching for a possible solution and have tried tampering about with the script as well as structure file however I have not managed to address this problem.
For reference, here’s a copy of the script that I’m using: http://pastebin.com/raw.php?i=9LjwJmSR
Kind Regards & Best Wishes,
John Smith
