I have calculated the total density of states and partial density of states for the GaAs with and without SOC using the input file given in here.
I then sum over all PDOS values to compute the contribution of each element in the TDOS. Here are the figures that I’ve generated.
NoSOC_GaAs.pdf (22.5 KB)
SOC_GaAs.pdf (25.5 KB)
Here is the individual l,m contribution for As, Ga for the case without SOC. For the reason that I have mentioned in my previous post I couldn’t prepare these plots for the nonzero SOC.
No_SOC_Ga_PDOS.pdf (46.1 KB)
No_SOC_As_PDOS.pdf (44.3 KB)
As I can see the summation of PDOS of Ga+As didn’t give me TDOS. I have tried with other cases and I came to the same conclusion. I first suspect that there is an error in my script to calculate the sum of PDOS. I have tested my script with a simple test file and the script worked just fine. Do you know how I can deal with this issue?
I also attached my input file for easy reference.
input.xml (955 Bytes)
