sorry i dont explain clearly.
i modify the code for include langevin, and compute_modify
i am begining to understand some of what do you tell me in previous mails.
due to i put velocity only in g_gas other atoms not update the temp and velocity.
now i incluye the compute temp to all atoms (is this right?)
and include the compute_modify dinamic yes (atoms moving out of one area take properties of new areas).
i make the simulation of deposition in steps, first step i simulate the deposition of Ga atoms in a GaAs sustrate.
after that i analize rebuild the structure and take only the atoms in the botton part of simulation.
include the new As atoms in the upper area and use the same lammps script for simulate the new atoms deposition (becouse i dont know how to use deposit yet).
i dont know if the script i add in the botton of this email is correct or i need to add some more.
Thank a lot.
With King Regards,
Bernardo
Actual code for simulation.
Initialize
clear
boundary p p f
atom_style atomic
Create atoms
read_data data.GAAS_progresivo
SW Potential
pair_style sw
pair_coeff * * parametros.sw Ga As
Define Settings
#base
region r_bottom block INF INF INF INF INF 3.0 units box
group g_bottom region r_bottom
#sustrato a 49 es el original
region r_middle block INF INF INF INF 3.1 49.9 units box
group g_middle region r_middle
#area intermedia de 50 a 64.9
region r_deposition block INF INF INF INF 50 64.9 units box
group g_deposition region r_deposition
area superior gas
region r_gas block INF INF INF INF 65.0 INF units box
group g_gas region r_gas
#parametros
velocity g_gas create 1000 492459 rot yes dist gaussian
compute 1 all temp
compute_modify 1 dynamic yes
fix nve_deposition g_deposition nve
fix fix_bottom g_bottom setforce 0.0 0.0 0.0
#fix nvt_deposition g_deposition nvt temp 600 800 0.1
#fix nvt_middle g_middle nve
#fix nvt_middle g_middle nvt temp 600 800 0.1
fix nvt_middle g_middle langevin 550.0 650.0 1000.0 639483
fix nvt_gas g_gas nvt temp 1000 1200 0.1
fix muro all wall/reflect zhi EDGE
thermo 5000
#thermo_style custom step temp pe etotal
thermo_modify lost ignore
Diffusion run
dump salidadump all atom 20000 dump.salidaprogresiva
#si el paso es mas grade da NaN (0.05 fallaba).
timestep 0.001
#restart 100000 deposicion.restart
run 1000000
undump salidadump
dump dumpfinal all atom 100000 dump.finalprogresiva
minimize 1.0e-4 1.0e-6 1000 10000
Your questions and explanations are unclear. There could
be any number of reasons why you don’t get a good structure.
