Hi all,
I wanted to point out a couple of things. First the docs for pymatgen_diffusion on guide.materialsvirutuallab.org seem to be out of date (a copyright date of 2016) shows up and packages such as pymatgen_diffusion.aimd.rdf module seem to be undefined. Can this be fixed?
The second topic regards the anaconda install of pymatgen_diffusion. Using anaconda (on linux) to install pymatgen_diffusion appears to be missing a dependency joblib. Attempting to run the example notebook pymatgen-diffusion/examples/radial_distribution_function.ipynb, results in the error that joblib cannot be found. A manual install using conda fixed this problem, but perhaps it should be fixed elsewhere as well.
from pymatgen_diffusion.aimd.rdf import
RadialDistributionFunction, RadialDistributionFunctionFast
from monty.serialization import loadfn
import matplotlib.pyplot as plt
%matplotlib inline
