Hi every,
I want to simulate the volume vs pressure (or temperature) in Al using the LennardJones612_UniversalShifted__MO_959249795837_003 model in the openkim. The error occurs in the process as follow: ERROR on proc 19: Neighbor list overflow, boost neigh_modify one (…/npair_full_bin_atomonly.cpp:90).
If you can give me some advice I would be very grateful.
Qiang Li
The input file is as follow:
variable x index 1
variable y index 1
variable z index 1
variable xx equal 10*$x
variable yy equal 10*$y
variable zz equal 10*$z
atom_style atomic
newton off
lattice fcc 4.4300
region box block 0 {xx} 0 {yy} 0 ${zz}
create_box 1 box
create_atoms 1 box
pair_style kim LennardJones612_UniversalShifted__MO_959249795837_003
pair_coeff * * Al
mass 1 26.98
velocity all create 300.0 98626 dist gaussian
thermo 100
neighbor 0.3 bin
#fix 1 all nve
fix 1 all npt temp 300.0 300.0 1.0 iso 0.1 0.1 3.0
run 10000
