I am using Pymatgen to analyze phase diagrams, and I have noticed that the coefficients for the decomposition products of certain unstable phases are not quite correct.
As I understand it, when a balanced chemical equation is given as C = XA + YB, the ‘get_decomp_and_e_above_hull’ function in Pymatgen, by default, should print out xA + yB, with x and y normalized so that x + y = 1 (x = X/(X+Y), y = Y/(X+Y)).
However, when I run the code for the simple case of B2S3,
decomp, ehull = pd.get_decomp_and_e_above_hull(PDEentry_for_B2S3)
data[“Decomposition”].append(" + “.join([”%.2f s" (v, k.composition.reduced_formula) for k, v in decomp.items()]))
the output shows 0.60 BS2 + 0.40 BS instead of the expected 0.50 BS2 + 0.50 BS. According to the balanced equation B2S3 = 1 BS2 + 1 BS, the coefficients should be 1/2 for each product. I’m curious to know what algorithm Pymatgen uses to obtain the values of 0.6 and 0.4.
Many thanks~
