I am trying to run a peridynamics simulation where a cylinder rotated around the y-axis impacts a rigid plate. However, atoms on the rotated cylinder are being cut off at the bounding box of the original, unrotated region. I’ve been changing the size of the cylinder region to see if anything changes but it isn’t working. I can’t seem to figure out the problem. The bounding box should change when the cylinder rotates?
I attached a screenshot of the cut off cylinder and a copy of my input file.
units si
atom_style peri
atom_modify map array
neighbor 0.0010 bin
lattice sc 0.0005
# Desired box
region box block -0.1 0.1 -0.04 0.04 -0.0012 0.1 units box
# Create desired target
region target block -0.03 0.03 -0.03 0.03 -0.0004 0 units box
#region target block -0.1 0.1 -0.04 0.04 -0.0012 0 units box
# Make 2 atom types
create_box 2 box
# Create the atoms in plate
create_atoms 1 region target
group plate region target
# Construct cylinder
variable y0 equal 0.00510 #sphere initial position
variable vy equal -60 #sphere initial velocity
variable theta equal 0.2932
region cyl cylinder z 0 0 0.01 0.002 0.047 rotate v_theta 0 0 0.01 0 1 0 units box
create_atoms 2 region cyl
group projectile region cyl
#Peridynamics style
pair_style peri/lps
# <type1> <type2> <K> <G> <horizon> <s00> <alpha>
pair_coeff 1 1 200e9 77e9 0.0015001 0.00672 0.5
pair_coeff 2 2 8.333e8 3.846e8 0.0015001 0.0008283 0.25
pair_coeff 1 2 200e9 77e9 0.0015001 0.0008283 0.25
#pair_coeff 1 2 8.333e8 3.846e8 0.0015001 0.008283 0.25
# Set mass density
set group plate density 15000
set group projectile density 917
# volume = lattice constant^3
set group all volume 1.25e-10
# Zero out velocities of particles
velocity all set 0.0 0.0 0.0 sum no units box
#Impose initial velocity to the sphere
velocity projectile set 0.0 0.0 v_vy units box
# Use velocity-Verlet time integrator
fix F1 projectile nve
# Compute damage for each particle
compute C1 all damage/atom
timestep 1.0e-7
thermo 200
dump D1 all custom 50 dump.ICE_YMP04 id type x y z c_C1
run 5000
