[lammps-users] the problem related with phase transition
Dear Lammps users,
I have the problem related with phase transition. My file is attach.
can you help me.
Thanks in advance
phase transition.doc (247 KB)
If you're getting NaNs on timestep 0 in your thermo output,
then your system is not intialized correctly - e.g. it has
overlaps.
2009/7/28 ahmet yıldırım <[email protected]...>:
I ran for16x16x16 region(N=4096 particle) and density=0.02. I dont have any problem. When I ran for 8x8x8 region(N=512 particle) Program is giving error.
I am getting “nans” after on timestep 0.
Step Temp TotEng Press Volume PotEng
0 1.9 4.6993414e+35 -1.8551831e+39 1333.3333 4.6993414e+35
100 nan nan nan nan nan
200 …
Dr.Roberto Berardi(works on liquid crystal) have got liquid crystal phase transition for N=512 and density=0.3 by monte carlo simulation but I dont obtain phase transition for N=512 and densitiy=0.3 by LAMMPS.
Thanks in advance
İnput file:
units lj
atom_style ellipsoid
lattice sc 0.02
region box block 0 16 0 16 0 16
create_box 1 box
create_atoms 1 box
set group all quat/random 982381
mass 1 1.5
shape 1 1 1 3
compute rot all temp/asphere
velocity all create 2.0 41787 loop geom
pair_style gayberne 1.0 3.0 1.0 4.0
pair_coeff 1 1 1.0 1.0 1.0 1.0 0.2 1.0 1.0 0.2 4.0
neighbor 0.3 bin
timestep 0.002
thermo_style custom step temp etotal vol epair press pe
thermo 100
fix 1 all npt/asphere 2.0 2.0 0.1 xyz 0.0 8.0 0.1
run 50000
unfix 1
fix 1 all npt/asphere 2.0 2.0 0.1 xyz 8.0 8.0 0.1
run 50000
28 Temmuz 2009 17:50 tarihinde Steve Plimpton <sjplimp@…24…> yazdı:
Your initial configuration is likely not correct, if the
timestep 0 energy is inifinite.
2009/7/30 ahmet yıldırım <[email protected]...>:
Allrigt, how can I correct/adjust the initial configuration? can you help me
Thanks in advance
adlı kullanıcı şunu yazmış:
No - you have to setup a correct model for LAMMPS
to simulate it. It's unlikely anyone on the mail list
is going to help you learn MD. I'd suggset finding
a paper that does something similar to what you
want and starting with that.
2009/8/2 ahmet yıldırım <[email protected]...>:
