I am simulating BNNT. I generated a lammps input file for building BNNT using VMD. but when I run input script stops at read data command without giving any error. I have attached data.bn file. Plz check and guide me why it is stopping at this step without error.
The following is the structure of input scrip
boundary p p f
atom_style atomic
newton on
what do you mean with "there is no error"? i get this:
[email protected]... Downloads]$ ~/compile/lammps-icms/src/lmp_serial -in in.bnnt
LAMMPS (24 Oct 2015-ICMS)
Reading data file ...
ERROR: No bonds allowed with this atom style (../read_data.cpp:972)
Thank you axel for quick response. But indeed I am getting no error.
LAMMPS just stops there with no error in logfile.
that doesn't make your input more correct. the error message i quote is
pointing out very clearly what is wrong. MD is always GI-GO (= garbage in,
garbage out). if you feed it bad data, you cannot expect bad behavior.
it also hints that you are not using the latest version of LAMMPS and that
you are violating several of the "10 commandments" for posting to the
LAMMPS users mailing list. http://lammps.sandia.gov/guidelines.html
please also note that what kind of topology information and atom style you use is usually determined by the force field and/or potential style. the data file you posted was apparently created for use with the CHARMM force field, IIRC.
then you didn't create a correct data file in the first place. topologies
for manybody potentials *must* not have any explicit
bond/angle/dihedral/improper data included, as they are implicitly computed
by the pair style in LAMMPS. GI-GO!
thank Axel. Now I removed extra things but it still not giving any error. just stop at read_data command. I am attaching my input script, logfile and data file here please suggest.
