I have attempted various methods of applying shear to a 3D simulation cell containing a dislocation dipole, and/or a single dislocation with a free surface.
No matter which method is applied (see the following detailed overview of methods), I find that the stress inverts periodically!?! In-plane shear stresses (τyz & τxy ) seem to interact.
You can see a simple example of my approaches and the inversion effect at the link:
https://drive.google.com/file/d/0B2_Hf1VNpOkpTmJoUWxwMHpmNlk/view?usp=sharing
To provide some context, I provide the following details.
Sorry for the wall of text which follows:
This does not occur as the dislocation crosses the periodic boundary, but rather what happens is the two complimentary shear components interact.
I evaluate the stress with respect to both the total volume and just the shear stress on the mobile atoms (i.e., sum of stress/atom of τyz & τxy components of mobile atoms only, divided by the approximate volume of the region containing mobile atoms).
I use zero normal displacement boundary conditions on the shear boundary layer, and periodic boundaries in the in-plane dimensions.
Shear is applied via several methods:
Equal and opposite velocity applied to top and bottom layers (i.e., velocity topLayer set 1.0 0.0 NULL
velocity botLayer set 1.0 0.0 NULL -
Velocity only applied to top layer
velocity botLayer set NULL 0.0 NULL
- Force added to layers
velocity topLayer set NULL 0.0 NULL
fix addForceTop topLayer addforce 1.0 0.0 0.0
fix addForceBot botLayer addforce 1.0 0.0 0.0
- Setforce method
fix addForceTop topLayer setforce 1.0 0.0 0.0
fix addForceBot botLayer setforce 1.0 0.0 0.0
in all cases I use the following constraints:
fix nve BoundaryAtoms nve
fix nvt mobile nvt temp 300 300 100
