Dear all, hope you are well and had a happy break for the Labour day
I am trying to use fix wall/gran wiggle command to compress just one single sphere by rigid walls.
Following the very useful suggestions from experts:
I tried to use this wiggle to shear the particle.
however, i have a weired problem that i cannot actually see the contacts between my clump and the wall. I made a mistake for not including time integration.
i therefore added
fix 5 all nve/sphere for one finite-size particle.
fix 5 all nve/bpm/sphere for bpm-created clump.
but i still cannot identify the contact between sphere and the wall.
to find the reason, i changed the bpm clump to just one simple sphere, however, i still cannot really identify the contact.
I generated this sphere with top boundary 0.01261; bottom boundary -0.00501. as illusrated in the image, they are close to clump but not really contacting the clump
the boundary is p p f, the rigid boundary in z direction;
i used
fix 3 all wall/gran hooke/history 1e20 NULL 50.0 NULL 0.5 0 zplane -0.00501 NULL contacts
fix 4 all wall/gran hooke/history 1e20 NULL 50.0 NULL 0.5 0 zplane NULL 0.01261 wiggle z 0.1 0.1 contacts
The top wall should show wiggle behaviour and contact the single since the amplitude is 0.1 m; it shoule be really large to the contact the between wall and sphere.
however i cannot really identify the contacts between clump and wall.
this is confirmed by
dump 7 all custom 100000 r100d2_contact/dump*.contact f_4[1] f_4[2] f_4[3] f_4[4] f_4[5] f_4[6] f_4[7] f_4[8]
for a long time simulation.
i always get 0 for everything.
dose anyone have a idea that why i have this problem? Does I make anything wrong?
i attached the data file and input script for anyone’ reference.
single.data (175 Bytes)
r100d2.in (1.8 KB)
hope you have a nice day
best regards
