Can the processing get stuck in this state and, if so, how can I cancel this task and either not upload or re-upload?
Thanks for the help! ![]()
Unfortunately, if something goes really wrong, everything can happen. There are a few CLI functions you can use. You need to execute them from one of the Oasis containers, e.g. with something like this:
docker exec -ti nomad_oasis_app bash
Then you have a few nomad commands to manipulate uploads. You can “reset” uploads, i.e. put back their processing state:
nomad admin uploads reset --with-entries -- <upload_id>
After this, you should be able to delete them in the UI again.
You can also ls, delete, or process them again (you might need to reset them first though):
nomad admin uploads ls --processing
nomad admin uploads rm -- <upload_id> <upload_id>
nomad admin uploads process -- <upload_id>
See also this bit on the documentation: Operating an OASIS - Documentation.
Let us know, if there are more problems with that.
Perfect - this works really well!! (I now prefer it over the web interface
One followup: I do have now this message when publishing (on our internal Oasis):
What/where would I look? I realize the logs may have the info, but they are so massive, that I am not sure where to look or what to look for…
Andre
The unpublished uploads are stored in .volumes/fs/staging/<prefix>/<upload_id>, the published uploads are stored in .volumes/fs/public/<prefix>/<upload_id>. When publishing a temporary file .frozen is created in the staging folder and the system starts to populate the respective public folder. The error message is about the .frozen file. I guess a previous attempt to publish, failed somehow.
You should remove the unfinished public folder and the .frozen file. Then you can reset the processing:
nomad admin uploads reset --success -- <upload_id>
and try to publish again.
If this fails again, please send the latest logs from the nomad_oasis_worker container. The last couple thousand lines should be fine:
docker logs -n 2000 nomad_oasis_worker
Let’s see if we can fix this.
Perfect - this solved the problem!!
My last question (for now
I am running processing of an upload in a terminal, using the command you gave above:
But it is “stuck” in:
1 uploads selected, processing ...
For a while now (3 days). Any suggestions for that? Would nomad_oasis_worker log output help with that, too?
Yes, the logs will help. I assume it is running into a problem, where it is unable to report an error or problem. With the logs, let us also know, which version (e.g. image tag) you are using.
